Announcements
Missing Option
mtaylor7KHWS3
Missing Option
mtaylor7KHWS3
How come I don't have the Project command in my creat drop down menu. I can find it in the right click menu, but it doesn't work
jhackney1972
The command Project is only available if you are in the Model Sketch Environment.  While in the sketch, "P" on your keyboard should bring it up.
John Hackney, Retired
mtaylor7KHWS3
OK, Thanks a lot. I found it there. The only thing I have missing is the purple lines of the body I am projecting. Is there a setting for this?
jhackney1972
You have to have the Projection Link option checked if you want the projected geometry to be linked (Purple Lines).
mtaylor7KHWS3
Thanks again
