missing Image on test
Steps to reproduce
I'm currently taking the Generative Design Expert Certification (practice test). I noticed that there is a message stating to refer to an image that doesn't exist.
"Refer to exhibit. GEN.03.02.01.png"
Expected results
I was hoping to have the image to refer to.
Actual results
A mechanical engineer is preparing a Generative Design study for a wall-mounted bracket that will have a cable spooled on the shaft of the pin pictured in the exhibit. The bracket will be affixed to the wall with 4 bolts that will engage with anchors in the wall.
The bracket must be manufactured out of AlSi10Mg in the +X orientation by an additive manufacturing vendor. The interface between the wall and the component will have surface finishing operations to ensure the roughness is within a specified tolerance after wire-EDM removal from the build platform.
Which two structural constraints must be applied to the depicted selections to ensure the bolt fixturing is represented correctly?
URL where issue occurs
https://www.autodesk.com/certification/learn/course/fusion360-generative-design-manufacturing-cert-p...
Browser
Microsoft Edge
OS
Windows
