Misplaced components when moving them in the browser
I'm having trouble positioning screws in an assembly. It's a large assembly, and I need grouped components, which I achieve through putting components within components within components. I have a group for screws, but since some time back, I get these warnings when I try select some imported screws and move them in the browser tree (after having broken the link).
Warning: CutPaste Screw MRT M2x6 92832A109_CLASS 8.8 TORX BUTTON-HEAD SOCKET CAP SCREW v1:4
Compute Failed
Warning: CutPaste Screw MRT M2x6 92832A109_CLASS 8.8 TORX BUTTON-HEAD SOCKET CAP SCREW v1:1
Compute Failed
Warning: CutPaste Screw MRT M2x6 92832A109_CLASS 8.8 TORX BUTTON-HEAD SOCKET CAP SCREW v1:3
Compute Failed
Warning: CutPaste Screw MRT M2x6 92832A109_CLASS 8.8 TORX BUTTON-HEAD SOCKET CAP SCREW v1:2
Compute Failed
After which the screws have moved in the global position to what seem to be random places, sometimes away back from the assembly.
This problem seem to dissappear if I export the assembly as a .step file, upload it and open a new design. The problem with this workaround is that I have drawings for some of the parts in the assembly that I want to keep associated to the ones in the exported assembly. So I wont have to remake a drawing each time I modify a component.
So my question is, can the misplace components bug be fixed or is there a way of associating a drawing with a component in a different design.
I would like to post some pics, but It's a file at work and thus secret material.
Best regards,
Marcus Bilgec
Robotics Engineer
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
Off of the top of my head and without seeing the model, my guess is there is something funky going on in the timeline if exporting and reuploading a sketch works. Can you try a couple of things to test this - if you go to the Modify menu and select compute all, do components go flying or any warnings/errors pop up? Would you mind creating a screencast and sending me the file via email (james.youmatz@autodesk.com) so I can take a deeper peek. My other thought is that it may have to do with the instanced components.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Hi James,
Thank you for responding so quickly!
Yep, I got 248 warnings and 2 errors (see the essay below) and the screws went flying. Do you need a screencast, or do you have further suggestions?
Error: MirrorComponent1
Compute Failed
Warning: Extrude3
1 Reference Failures
Failed to get owner occurrence transform
The profile reference is lost, try editing this the feature to reselect the lost profile.
Failed to get target occurrence transform
Warning: Extrude4
Fails to get associated relative position
Warning: Position1
Compute Failed
Warning: Position2
Compute Failed
Warning: Position3
Compute Failed
Warning: Position4
Compute Failed
Warning: Position5
Compute Failed
Warning: Position6
Compute Failed
Warning: Position7
Compute Failed
Warning: Position8
Compute Failed
Warning: Position9
Compute Failed
Warning: Position10
Compute Failed
Warning: Extrude1
Warning: Combine1
Tool Body Error
Warning: Position12
Compute Failed
Warning: Position13
Compute Failed
Warning: CutPaste M2 STAINLESS STEEL HEX NUT_91828A111_TYPE 18-8:2
Compute Failed
Warning: CutPaste M2 STAINLESS STEEL HEX NUT_91828A111_TYPE 18-8:1
Compute Failed
Warning: Position14
Compute Failed
Warning: Position15
Compute Failed
Warning: Position16
Compute Failed
Warning: CutPaste M2 STAINLESS STEEL HEX NUT_91828A111_TYPE 18-8:5
Compute Failed
Warning: CutPaste M2 STAINLESS STEEL HEX NUT_91828A111_TYPE 18-8:3
Compute Failed
Warning: CutPaste M2 STAINLESS STEEL HEX NUT_91828A111_TYPE 18-8:4
Compute Failed
Warning: Loft1
Warning: Sweep1
The model is using cached geometry to solve. Please reselect reference geometry for failed features in the timeline.
2 Reference Failures
Warning: Sweep1
Warning: Position17
Compute Failed
Warning: Position18
Compute Failed
Warning: Position19
Compute Failed
Warning: Position20
Compute Failed
Warning: Position21
Compute Failed
Warning: Position22
Compute Failed
Warning: Position23
Compute Failed
Warning: Position24
Compute Failed
Warning: Position25
Compute Failed
Warning: Extrude1
Warning: Extrude2
Warning: Extrude3
Warning: Extrude4
Warning: Extrude5
Warning: Position26
Compute Failed
Warning: Position27
Compute Failed
Warning: CutPaste 2017-04-18 Testassembly new contacts printheads v1:2
Compute Failed
Warning: CutPaste 2017-04-18 Testassembly new contacts printheads v1:3
Compute Failed
Warning: CutPaste 2017-04-18 Testassembly new contacts printheads v1:1
Compute Failed
Warning: Position28
Compute Failed
Warning: Position29
Compute Failed
Warning: Position30
Compute Failed
Warning: CutPaste Screw MRT M3x6_7045_8_-3__6-mattssons:43
Compute Failed
Warning: CutPaste Screw MRT M3x6_7045_8_-3__6-mattssons:40
Compute Failed
Warning: CutPaste Screw MRT M3x6_7045_8_-3__6-mattssons:42
Compute Failed
Warning: CutPaste Screw MRT M3x6_7045_8_-3__6-mattssons:46
Compute Failed
Warning: CutPaste Screw MRT M3x6_7045_8_-3__6-mattssons:47
Compute Failed
Warning: CutPaste Screw MRT M3x6_7045_8_-3__6-mattssons:41
Compute Failed
Warning: CutPaste Screw MRT M3x6_7045_8_-3__6-mattssons:45
Compute Failed
Warning: CutPaste Screw MRT M3x6_7045_8_-3__6-mattssons:44
Compute Failed
Warning: CutPaste MRT M3x20_7985_8_-3_20-mattssons:1
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:14
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:10
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:11
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:13
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:15
Compute Failed
Compute Failed
Compute Failed
Warning: CutPaste M3×5_7985 8 -3 5-mattssons:1
Compute Failed
Warning: CutPaste M2 STAINLESS STEEL HEX NUT_91828A111_TYPE 18-8:6
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:5
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:3
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:4
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:6
Compute Failed
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:12
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:9
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:7
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:8
Compute Failed
Warning: CutPaste SCREW MRT M2x6_7985___-2__6-mattssons:2
Compute Failed
Warning: CutPaste M3×5_7985 8 -3 5-mattssons:3
Compute Failed
Warning: CutPaste SCREW MFT M3x8_70464__-3__8-mattssons:1
Compute Failed
Warning: CutPaste SCREW MFT M3x8_70464__-3__8-mattssons:2
Compute Failed
Warning: CutPaste SCREW MFT M3x8_70464__-3__8-mattssons:3
Compute Failed
Warning: CutPaste SCREW MFT M3x8_70464__-3__8-mattssons:4
Compute Failed
Warning: CutPaste MRT M3x20_7985_8_-3_20-mattssons:2
Compute Failed
Warning: CutPaste M3×5_7985 8 -3 5-mattssons:4
Compute Failed
Warning: CutPaste M3×5_7985 8 -3 5-mattssons:2
Compute Failed
Warning: CutPaste Countersunk torx M3x8 92703A207_18-8 SS:2
Compute Failed
Warning: CutPaste Countersunk torx M3x8 92703A207_18-8 SS:1
Compute Failed
Warning: CutPaste 4x110 mm pneumatic tube:1
Compute Failed
Warning: CutPaste 4x100 mm pneumatic tube:1
Compute Failed
Warning: CutPaste bracket for x motor:1
Compute Failed
Warning: CutPaste linear_actuator_43F4C-2:1
Compute Failed
Warning: CutPaste 4/2.2 x 3mm spacer Ni plated brass 311220340050:6
Compute Failed
Warning: CutPaste 4/2.2 x 3mm spacer Ni plated brass 311220340050:2
Compute Failed
Warning: CutPaste 4/2.2 x 3mm spacer Ni plated brass 311220340050:4
Compute Failed
Warning: CutPaste 4/2.2 x 3mm spacer Ni plated brass 311220340050:5
Compute Failed
Warning: CutPaste 4/2.2 x 3mm spacer Ni plated brass 311220340050:1
Compute Failed
Warning: CutPaste 4/2.2 x 3mm spacer Ni plated brass 311220340050:3
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Warning: CutPaste Stepper_motor_ASM:1
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Warning: CutPaste Screws, nuts, washers and spacers:1
Compute Failed
Compute Failed
Compute Failed
Warning: CutPaste Microswitch ZMA00A150L04PC:2
Compute Failed
Warning: CutPaste Stepper_motor_ASM:3
Compute Failed
Warning: CutPaste Printbox USB:1
Compute Failed
Warning: CutPaste PCB Printheadmodule:1
Compute Failed
Warning: CutPaste Microswitch ZMA00A150L04PC:1
Compute Failed
Warning: CutPaste VV100-S41-03-M5_VV100-S41-03-M5:1
Compute Failed
Warning: CutPaste Push-in fitting; threaded, straight; outside; -1÷10bar; Mat: brass_KQ2E04-00NJ:1
Compute Failed
Warning: CutPaste Push-in fitting; threaded, straight; outside; -1÷10bar; Mat: brass_KQ2E04-00NJ:2
Compute Failed
Compute Failed
Warning: CutPaste Probe fixture:1
Compute Failed
Warning: CutPaste Stepper_motor_ASM:2
Compute Failed
Warning: CutPaste Push-in fitting; threaded, straight; outside; -1÷10bar; Mat: brass_KQ2E04-00NJ:3
Compute Failed
Warning: CutPaste Printmodule body Rev G v1:2
Compute Failed
Warning: Position31
Compute Failed
Warning: Position33
Compute Failed
Warning: CutPaste bracket for bearing x motor rod Rev A v1:1
Compute Failed
Warning: Position34
Compute Failed
Warning: CutPaste Pneumatic Printhead:1
Compute Failed
Compute Failed
Compute Failed
Warning: Position36
Compute Failed
Warning: CutPaste Pneumatic Syringe holder Rev B v1:2
Compute Failed
Compute Failed
Warning: CutPaste Pneumatic Printhead:2
Compute Failed
Warning: Position37
Compute Failed
Warning: Position38
Compute Failed
Warning: Position40
Compute Failed
Warning: Position41
Compute Failed
Warning: CutPaste X-gantry spacer Rev A v1:1
Compute Failed
Warning: Position42
Compute Failed
Warning: Position43
Compute Failed
Warning: Position44
Compute Failed
Warning: CutPaste LED Strip 100x10 v1:1
Compute Failed
Warning: CutPaste LED Strip 100x10 v1:2
Compute Failed
Warning: Position45
Compute Failed
Warning: Position46
Compute Failed
Warning: Position47
Compute Failed
Warning: Position48
Compute Failed
Warning: Position49
Compute Failed
Warning: CutPaste Pneumatic Printhead:3
Compute Failed
Warning: CutPaste LED Strip 100x10 v1:3
Compute Failed
Warning: CutPaste LED Strip 100x10 v1:5
Compute Failed
Warning: CutPaste LED Strip 100x10 v1:4
Compute Failed
Warning: CutPaste LED Strip 100x10 v1:6
Compute Failed
Warning: CutPaste LED Strip 100x10 v1:7
Compute Failed
Warning: CutPaste X-gantry spacer Rev A v1 (1):1
Compute Failed
Compute Failed
Compute Failed
Warning: Extrude8
Warning: Position50
Compute Failed
Warning: Position51
Compute Failed
Warning: Position52
Compute Failed
Warning: Position53
Compute Failed
Warning: CutPaste Printheadholder LEFT assembly_Linear-Guide-MGN7H1R0100Z0C-5-5-Aratron:1
Compute Failed
Warning: CutPaste Printheadholder RIGHT assembly_Linear-Guide-MGN7H1R0100Z0C-5-5-Aratron:1
Compute Failed
Warning: CutPaste Printheadholder RIGHT assembly_Linear-Guide-MGN7H1R0100Z0C-5-5-Aratron:2
Compute Failed
Warning: CutPaste Masked drawings:1
Compute Failed
Warning: CutPaste Printheadholder Assembly:1
Compute Failed
Warning: Sketch4
Project1
Project2
Warning: Sketch5
Project1
Warning: Sketch6
Project1
Warning: Sketch7
Project1
Warning: CopyPaste SCREW MFT M3x8_70464__-3__8-mattssons:14
Compute Failed
Warning: Sketch8
Project1
Warning: Sketch9
Project1
Warning: Sketch10
Project1
Warning: Plane1
Warning: CutPaste Haydon-43F4C-2 (1) (1):1
Compute Failed
Warning: CutPaste SCREW MFT M3x8_70464__-3__8-mattssons:14
Compute Failed
Warning: CutPasteBodies1
Error: RemoveInstance-null
Compute Failed
Warning: CutPaste Screw MFT M2x6_0965___-2__6-mattssons:5
Compute Failed
Warning: CutPaste Screw MFT M2x6_0965___-2__6-mattssons:7
Compute Failed
Warning: CutPaste Screw MFT M2x6_0965___-2__6-mattssons:8
Compute Failed
Warning: CutPaste Screw MFT M2x6_0965___-2__6-mattssons:6
Compute Failed
Warning: CutPaste Screw RTK FZB ST2:4
Compute Failed
Warning: CutPaste Screw RTK FZB ST2:5
Compute Failed
Warning: CutPaste Screw RTK FZB ST2:6
Compute Failed
Warning: CutPaste Screw MFT M2x6_0965___-2__6-mattssons:1
Compute Failed
Warning: CutPaste Screw RTK FZB ST2:3
Compute Failed
Warning: CutPaste Screw RTK FZB ST2:2
Compute Failed
Warning: CutPaste Screw MFT M2x6_0965___-2__6-mattssons:2
Compute Failed
Warning: CutPaste Screw MFT M2x6_0965___-2__6-mattssons:3
Compute Failed
Warning: CutPaste Screw MFT M2x6_0965___-2__6-mattssons:4
Compute Failed
Warning: CutPaste Screw RTK FZB ST2:1
Compute Failed
Warning: CopyPaste Screw RTK FZB ST2:7
Compute Failed
Warning: CopyPaste Screw MFT M2x6_0965___-2__6-mattssons:9
Compute Failed
Warning: CopyPaste Screw MFT M2x6_0965___-2__6-mattssons:10
Compute Failed
Warning: CopyPaste Screw MFT M2x6_0965___-2__6-mattssons:11
Compute Failed
Warning: CopyPaste Screw RTK FZB ST2:8
Compute Failed
Warning: CopyPaste Screw RTK FZB ST2:9
Compute Failed
Warning: CopyPaste Screw MFT M2x6_0965___-2__6-mattssons:12
Compute Failed
Warning: CopyPaste SCREW MFT M3x8_70464__-3__8-mattssons:16
Compute Failed
Warning: CopyPaste SCREW MFT M3x8_70464__-3__8-mattssons:17
Compute Failed
Warning: CopyPaste SCREW MFT M3x8_70464__-3__8-mattssons:18
Compute Failed
Warning: CutPaste Screw MFT M2x6_0965___-2__6-mattssons:10
Compute Failed
Warning: CutPaste M3x6 nylon roundhead hex :2
Compute Failed
Warning: CutPaste SCREW MFT M3x8_70464__-3__8-mattssons:18
Compute Failed
Warning: CutPaste SCREW MFT M3x8_70464__-3__8-mattssons:17
Compute Failed
Warning: CutPaste SCREW MFT M3x8_70464__-3__8-mattssons:16
Compute Failed
Compute Failed
Compute Failed
Compute Failed
Compute Failed
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
That's a lot of text..... To be honest, I'm not too sure off of the top of my head why all these errors may be occurring. Something definitely lost its reference. Do you mind inviting me to the project so I can take a deeper peek. My email to invite is james.youmatz@autodesk.com
James Youmatz
