Announcements
Mirrored Chamfer feature doesn't match original
suretech1
suretech1
Hello, I did a lot of searching but could not find an error. Most results were mirrored features not working at all.  Mine Chamfer features mirror, except that distance/distance does not match the original(different dimensions).  I have tried Optimized, adjusted and identical. with no difference. I have tried using face mode and selecting faces. I have also tried feature mode and selected features from the timeline.
I can apply the chamfer individually to each side as a workaround but I feel this is a simple enough calculation that the software should be able to handle it.
Thanks for the help.
TheCADWhisperer
I would have used Revolve rather than Loft.
Interesting result though - looks like a bug to me, but I will have to dig deeper.
What difference are you observing if you change the Mirror output to Optimized?
suretech1
EDIT: I chose "Optimize" and that fixed the issue.  I swear I chose optimize. I apologize for that. Thanks again!
Revolve entered my thought briefly at the beginning.  This would only be useful for the main profile correct? I would still need to add in my tabs after Revolve feature?  Is this why my mirrored chamfer is not coming out properly?  I will experiment in the meantime.
Thank you for the quick reply.
Joe
g-andresen
select all features included
I prefer "Faces"
günther
