Mirror issues
Mirror issues
Hi everyone, all good?
So I developing an CFD on SimScale for a X8 flying model, I grab a reverse enginnering model from grabcad (https://grabcad.com/library/skywalker-x8-reverse-enginnering-process-overview-1/details?folder_id=17...) and imported the following to Fusion360.
Which result to me on the following:
My problem is: I need to mirror the wing portion to have the full model and then exporte as .stl. Using the mirror tool I get following
Which is my goal, but as soon as pressed OK, the following happens:
It mirrors on the same place as the orginal.
Any advice on how to solve this issue?
Best regards
TheCADWhisperer
Thanks for the quick reply! Will do it
Just to add -- I try create new offset planes, but same result.
Best regards
Lucas Colonna
TheCADWhisperer
I don't see where you converted the mesh to solid bodies?
The mesh looks to be very poor quality to me.
I would use only as reference in creating high quality native geometry.
Hi!
Indeed i didnt do this step!
I tried now and receive the following error message:
Do you have any advice or tutorial that I may follow?
