Announcements
Mirror feature doesn't work as intented
gery.springer
gery.springer
Hi community,
i try to mirror a "hole" feature and it's not working as intented, i think.
The hole command cuts holes through body 1 and 6, the mirror feature should cut through body 1 and 5, but it cuts only through body 1.
I've  attached the file with the problem.
Thanks in advanced,
Gery
hamid.sh.
@gery.springer wrote:
...The hole command cuts holes through body 1 and 6, the mirror feature should cut through body 1 and 5, but it cuts only through body 1...
I think that's the whole point; in Hole (or other command e.g. Extrude) you specify the body to be altered. Mirror (and also Patterns) copy profile, cut distance and target body list. If body ID is different how can Fusion know which body it must alter? Your model is simple, but in a case where you have two overlapping bodies (say body 5 and body 4) and choose to cut hole only in body 5 how can Fusion decide affected body in mirror position?
One simple solution is first join body 5&6, mirror, then separate them again. Like this:
Hamid
g-andresen
hi,
another way:
günther
gery.springer
Ok, thanks! Second solution would be best.
I already achieved it another way, but good to know!
Thanks!
BR
Gery
