Message 1 of 12
How do you mirror a line ??????
Hello @charlescooke58 ,
If you are in sketch environment and want to mirror a line, follow below steps.
Let me know if this helps, Thanks!
Thanks for that, that is what I did, in the diagram I selected the mirror comd. then it wouldnt allow me to select the spline, but I could select the centre line. So obviously I have done something else wrong.
Hi @charlescooke58 ,
Would you be able to send me the model?
Thanks!
Why is everything associated with Fusion 360 so difficult please explain how I do this I am always having problems sharing a file.
Sorry for the trouble you are facing.
For sharing the file, you can just drag and drop the file in this reply.
Thanks!
I hope you got it.
I see that the sketch you created for the spline is a 3D sketch and looks like the 3D curve is not selected as object for the 3D sketch in mirror.
I am checking with the team now and will get back to you on this
Thanks!
Hi,,
1. Move to sketch plane
2. Mirror Profile
günther
Before you continue, you should correct the numerous mistakes.
Just got the sketch or feature that is having issues, review warning and take necessary actions.
Thanks!
