Fusion Support
Mirror a Component - Axis Through Cylinder - Referenz is lost
3 REPLIES 3
Christoph_360
91 Views, 3 Replies
Hello
Axis through Cylinder 2 has lost his Referenz to the Cylinder after the Mirror of the Component
Christoph
3 REPLIES 3
It is not losing Reference, it is just the length of the axis line that is not updating.  I do not know how to make it update except to make the axis long enough to cover both configured components.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
One solution would be to add an extra axis and then suppress the visibility of one or the other depending on the configuration showing.
John Hackney
Retired
Hello
You're right, that's true, thank you for your reply.
It is not losing the Reference, the problem is, that the axis is only updated when the hole is moved.
Christoph
