Messed up patches due to parameter change
I have modelled some furniture in Fusion 360 and inserted the file into a CAM setup file with stock set up for laying out and programming for SHOPBOT CNC.
I have tried both using nester and manual using 'align' tools to lay all the pieces flat.
As I'm going I may come across something that needs adjusting in the design - eg a dogbone missing. I do this adjustment in my original file and save.
When I go my layout file and hit 'get all latest' for the updated linked data, the layout gets all messed up and I have to start again!
Is there a solution to this? it seems every time I change a parameter or a feature I have to set up the layout and nest all over again which is very time-consuming - I thought the whole idea behind CAD/CAM was that everything was linked so could be updated easily.
It seems to be an issue with JOINTS. I've tried many things to fix but no joy.
Also - when I close my layout file and reopen - previously supressed joints seem to now be unsupressed.
I'm using Mac book air
PLease help !
this is what happens when i update - components all previously layed flat and nested
masa.minohara
This seems to be a duplicate of this one: https://forums.autodesk.com/t5/fusion-360-support/nesting-cad-cam-linked-file-problem-with-changes-g...
Please see my comment there.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
