Fusion Support
Meshing Error while trying to do a simulation
1 REPLY 1
aruiz40DNGK7
83 Views, 1 Reply
I'm trying to do the following simulation in this file. The thing is that every time I try to solve the simulation it always fail. It always is because meshing errors. Also, when I tried to solve the simulation when it failed it said something along the lines of "body is too thin" or something like that I didn't take a ss of that. Mostly, I think it is due to meshing errors and I don't know how to fix this. The design is not mine, I simply need to complete some simulations using this design but I can't because every time the simulations fail. I'd like to know what is wrong with the design as well as how to fix it.
I have attached the .f3d as well as a screenshot about what is happening.
Labels (4)
1 REPLY 1
henderh
in reply to: aruiz40DNGK7
Hi @aruiz40DNGK7,
The mesh fails due to the way the frame is modeled with the hollow pipe features.
There are two solutions described here: https://forums.autodesk.com/t5/fusion-support/fea-static-stress-simulation-unknown-error-solver-erro...
Hope this helps!
Hugh Henderson
QA Engineer (Fusion Simulation)
