Try again, can you see the mesh workspace?
i tryed 3 times but still dont work...
First can you verify what build of Fusion you are using? Go to the Help menu, and find the About command.
In the box for About, is your build number 2.0.9305?
Another thing you can try is to open a blank document, then use the small gear icon in the lower right corner to turn off timeline history. The option is "Do not capture design history".
After that, is there a mesh tab on the toolbar? If yes, then turn on timeline history again by right clicking the top node of the model browser and using "Capture design history".
Do you have access to the mesh workspace now?
the build is the same, I tried following your instructions but still nothing. thanks for support
Sorry this is not working. One more.
Try this,
now it work, but if i open a new tab mesh workspace is not active
Thanks for confirming that. The issue is logged as a bug report.
Did you try this workaround? (I'm just trying to ensure the most simple workaround is available to you and others)
If you are starting a new design, do these steps help?
now it worb but i need to follow this step every time
thanks a lot.
