Mesh to body.
Mesh to body.
m.van.hameren
Message 1 of 15
Mesh to body.
m.van.hameren
Hi all,
I'm in the middle of coverting imported meshfiles to body's in fusion.
There's lots of warnings about to many triangles/faces.
So first after checking this tutorial: https://youtu.be/tVGtG-UjlYg it will get me started but it takes a hell of a long time (Fusion warnes me for that). Is al this converting done locally on my computer or in the cloud somewhere on Fusion datacenter?? So will I be better off with a more powerfull PC with more internal memory and high upgraded processor?
Thanks once again for your time. Mark.
Replies (14)
Message 2 of 15
mzulchDTD74
First thing i would do is before trying to convert from an STL to a solid check the scale of your model. I have noticed almost always the model is opened in cm vs the mm i would usually design something in. This makes the model 10 times larger than intended. If you scale it down to the correct scale, a lot of times this makes the conversion to solid go a lot smoother. At least this works for me.
Message 3 of 15
m.van.hameren
It is in mm, size should stay the same.
Fusion crashes when converting to body.
Message 4 of 15
mzulchDTD74
it does not hurt to double check. mm models open in cm for me. Just an FYI.
Message 5 of 15
TrippyLighting
Converting faceted mesh models into Solids is often a bad idea. Can you share the model in original .stl format ?
Message 6 of 15
m.van.hameren
Okay, thaks for your time.
Message 7 of 15
WHolzwarth
As Peter (@TrippyLighting) already mentioned, only in special cases (further 3D editing) it makes sense.
Here's BREP of this file. Filesize 5766 kB as STL, 33653 KB as F3d.
Walter Holzwarth
Message 8 of 15
HughesTooling
I guess you're uploading your models through Fusion's data panel, and yes the online translators default to CM. If you use insert mesh Fusion will default to document units and you also have the option to override the units on the insert dialog.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 9 of 15
m.van.hameren
Hey,
Thanks all for your reply's.
Ik really need the solid to make a castmold for it which will be printed on a 3d printer. You can't do it when it is still a mesh (sadly enough).
You can make the castmold in meshmaker too, but I want the castmold to be split in two parts (devidable?) and that I want to accomplish in Fusion. The mould itself is actually a silliconerubber flap, now I had to cut the castmold open with an oscillating saw. The flap is used in a medical situation, so needs some care,
Message 10 of 15
m.van.hameren
So how did you accomplish this?
greetz, Mark.
Message 11 of 15
TrippyLighting
Often the best way to do this in a CAD application is to first re-mesh the triangulated scan data into a quad mesh.
That quad mesh then can be imported into Fusion 360, converted into a T-Spline and then BRep.
the large advantage over a faceted BRep created by directly converting a mesh into a BRep is that the result is not faceted .
I have created this tutorial a few years ago and it has worked many times, although in my current attempt Fusion 360 fails to convert the mesh into a T-Spline it is still worth trying:
Message 12 of 15
WHolzwarth
That's only a big deal with respect to filesize.
In Mesh environment -> Modify -> Convert Mesh with Method Faceted. After some time you'll get a BREP with thousands of tiny faces.
With the result a boolean cut could be done versus a solid box. But the real challenge will be parting line creation for the cavity.
Shortly after writing: Peter has been there already.
Walter Holzwarth
Message 13 of 15
TrippyLighting
Attached is a model with a quad-mesh face count around 20,000, created with the workflow in the tutorial.
That high face count might not be needed to retain the detail of the scanned mesh.
Message 14 of 15
TrippyLighting
This can generally can be done entirely using a mesh-only based workflow. It would not NOT involve Fusion 360!
Message 15 of 15
m.van.hameren
Working in Meshmaker now to create a castmould.
Thanks for your answers!
Mark.
