mesh problem
Hi, I am having a lot of problems with a mesh. I want to make a completely solid transducer so I can make a negative of it to make a transducer holder.
However, after doing repair, erase and fill, generate face groups, and validate actions, I am still not able to get a solid file that I can use to make a negative.
After converting the presumably faulty mesh to a solid, I get errors like:
"There was a problem combining geometry together. If
attempting a Join/Cut/Intersect, try to ensure that the bodies
have a clear overlap (problems can occur where faces and
edges are nearly coincident). "
or
coincident intersection edge previously non-coincident"
If anyone can help that would be much appreciated, I have attached the file.
