Announcements
Merge
Merge
How can I create a smooth join between the raised and the outer edge?
g-andresen
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
günther
Sorry I`m quite new to Fusion 360.
I have attached the file to this reply.
g-andresen
something like that? > Fillet 3 mm
günther
Thanks for fast reply.
Sort of.
Maybe this helps explain what I'm trying to achieve? Trying to get it to be a steady curve instead of a step, if that makes sense?
wmhazzard
Here is one way that might work for you. I offset the vertical face past the outside of the die and deleted the underside overhanging face.
Perfect thanks
