Measure tool not showing distance
FrodoLoggins
Advisor Advisor
Message 1 of 8
FrodoLoggins
In the below video I'm trying to measure the distance between parallel faces. The measure tool displays the angle between the faces [0º] but never shows the distance between the two faces:
Geometry created in Fusion by extruding sketch objects.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Replies (7)
Message 2 of 8
jhackney1972
The two faces, you are measuring between at a "very" small angle to each other.  Fusion 360 will not give a distance between two faces unless they are parallel to each other.
John Hackney, Retired
Message 3 of 8
jeff_strater
Distance between planar faces is only reported if the faces are parallel.  If they are no parallel, the angle is reported.  These are off by just a little:
Jeff Strater
Engineering Director
Message 4 of 8
FrodoLoggins
Test comment
Message 5 of 8
FrodoLoggins
Hi thanks.
Any idea why those faces are at an angle? The below video shows how I created those soft jaws. I did not drive a sketch off an offset plane that was rotated 1.382E-05º. I drove the first sketch off the origin's XY plane, extruded the rectangle, drove the second sketch off the top of the extruded rectangle and then extruded the circles.
Message 6 of 8
FrodoLoggins
I keep getting this error when either attaching a video or image. Let's hope it works this time.Screenshot 2022-11-30 at 8.13.04 AM.png
Message 7 of 8
FrodoLoggins
Here is a link to the video showing how I created the geometry in my OP. Let's hope this works
https://youtu.be/nix0Iq-3ijY
Message 8 of 8
HughesTooling
@FrodoLoggins wrote:
Hi thanks.
Unfortunately with no history recorded there's no real way to figure out where this has gone wrong.
There are some oddities like this shows 90°
And This!
So top face and bottom of cylinder should be parallel!
But an axis through the cylinder shows an angle between the face and the cylinder centreline. But with no sketches left in the design and no history hard to know where and why it's gone wrong.
Mark
Mark Hughes
Owner, Hughes Tooling
