Announcements
Measure during command no longer working?
Art5
Art5
It used to be that during a move command I was able to use the 'measure' function provided by the three dots to the right of the xyz distance/angle boxes to measure distances/angles and it would automatically populate the respective box with the measured amount. I noticed today during a move command that I can still activate the measure function in the same way, but when I select the two entities I'd like to measure between it doesn't appear to work; the measure function stays active and the box doesn't populate, it just remains '0'. Is this something others are experiencing?
Any and all help is greatly appreciated,
Art
jhackney1972
It still works as it always has.
John Hackney, Retired
jhackney1972
I just re-read your post.  You are not measuring an entity, but BETWEEN two entities.  I will have to say that that does not work as expected.  Sorry, did not look read it close enough.
Art5
I can say with a fair amount of certainty that in the past I've been able to successfully use this function to measure BETWEEN two entities, but not anymore.
CGBenner
@RajkumarIlanchelian  Does this sound like something that needs to be investigated?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Phil.E
Thanks @CGBenner.
Before I logged a bug report for this I tried the latest Fusion Insider build, which came out today, and find the issue is fixed.
Insider is targeted for release in a few weeks.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
