MATING TWO COMPONENTS LIKE SOLIDWORKS
s222290629
s222290629
Hi ,
I need your guidance to show me how can put this control switch on the blender base body, looks like "Solidworks"?
Kind Regards,
Arman
jhackney1972
Please attach your model so the Forum users can give you help with your actual question using your model.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
s222290629
That's not the way I'm looking for, i.e., save as it or attaching the file. I am a new starter and need to do more practice, not give it to sb and draw it for me, this is not the way...I hope you got it.
For attaching guidance, thank you so much.
TrippyLighting
Yep, we got it. Have at it then and continue to practice. Good luck !
