Announcements
Math project at school
Hello, I need help making this object (attached) in Autodesk Fusion 360 for a math project in school. Can someone please help me out and create the STL file for me? If U could also create a video showing me how to do it also it would be greatly appreciated 🥰 but the video is optional but it would be nice so I could learn how to do it myself. The size of the box can be 7" x 7" square but if you can also do the video and tell me how to scale it would be very helpful 🥰. Thanking you in Advance Cecil Williams. Privacy level can be public because it's for a math project in school.
Accepted solutions (3)
davebYYPCU
Leg of the square is D1
which is equal to 7 in, change that to scale it.
Timeline should suffice....
Might help....
Thanks 😊 that's awesome!! Can you please explain how U did it? It don't have to be a video. U'r fantastic!
davebYYPCU
Sketch a centre point rectangle.
Dimension one side to 7 inch.  Make the other side equal to the first side.
Sketch a circle - snap to a corner point.
Your first dimension is D1, inside the system.
Surface > Extrude the rectangle, (square now) set Distance to “D1”
Make a Plane at Angle, Use a diagonal line, set angle to vertical.
Sketch on that Plane, Sketch > Project 3 of the corner points of the box,
Sketch 3 point circle.
Edit / change the first dimension, and Fusion will scale the model.
Make an Stl File from that was not understood, so stopped there, check to see if I got close to your request.
Might help...
Hello davebYYPCU,
  1. It's pretty darn good. Can you also add another circle of equal value to the top of the Box?
  2. And then another circle of equal value at the opposite side of the second circle, it should intercept the second circle at the top and bottom.
In regards to the ".STL" it's the file extension for the math project that you have created for me. I'm just requesting that you attached it to this blog post so I will be able to make modifications if needed as well as submit it with my math class.
Thanks 😊 in advance
In regards
Hi @davebYYPCU
In regards to the ".STL" it's the file extension for the math project that you have created for me. I'm just requesting that you attached it to this blog post (or email it to nextgentek@gmail.com) so  I will be able to make modifications if needed as well as submit it with my math class teacher for a grade)
Thanks 😊 in advance u'r a life saver!🙏God Bless you 😇
In regards
