I've found two bugs:
When custom material library is added to Manage Materials dialog, and after that it is deleted permanently from disk, and again I open Manage Materials dialog, this library is with exclamation point badge. If I remove this library from the list and open again Manage Materials dialog, this deleted library appears again:
The second point:
If I have my own material and I would like to change the path to texture file, I should:
- Edit appearance (it will add my appearance to Favorites);
- Change the path;
- Click Save;
- Add/Return ths appearance to my library.
Unfortunately, This edit is not saved and the path to texture is the old one.
