Manufacture Simplify Chamfer problem
Davidf01
Davidf01
I'm using the arrange feature to arrange items for CNC cut. When I try to use the simplify feature to remove chamfers for the models Fusion does not detect the chamfers. Is this a bug or am I missing something?
seth.madore
How were they modeled; with the Chamfer command? Can you share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Davidf01
Hi Seth,
Yes I used the chamfer command. Here is the parts of the file that have the chamfer issue. I deleted parts of the file that are not part of this so you may get some sketch errors but thats on different parts.
seth.madore
It appears there are either size limitations of what you can remove, or there are timeline issues with removing those features. In the Design space, if I suppress those chamfer, the resulting body is quite....basic:
Seth Madore
Davidf01
Yes if I suppress the chamfers I get the same thing and I cant seem to move the chamfer in the time line. Normally I can move the chamfer feature in the timeline.
