Announcements
Manual length input for lines, diameters, etc.
gbeniaris
gbeniaris
Hello.
I want to do more precise measurements when creating forms, and I see the box pop up with the number and the measurement type, but I can't select it to type anything in. Is there way to do that?
jhackney1972
It is not clear which boxes you are referring to.  As you can see, when I create a Form Cylinder, the entry boxes are fully editable.
John Hackney, Retired
gbeniaris
Ahh, I see I was not quite clear. Perhaps I should have included a picture. Apologies.
In your picture with the cylinder, I mean the small input box in the middle of the cylinder, with the highlighted number. How do I use that for precise adjustments? Is there a keyboard shortcut for that?
jhackney1972
You would simply type in the value you desire.  The box number is highlighted ready for input.  If you need to change the precision, number of decimals, go to Fusion 360 and change your Units precision.
