Announcements
Manage Extension - Add Part or drawing to existing CO from Manage menu.
iain.mcvey
iain.mcvey
I have existing CO's and I need to add additional parts and drawings to them.  Currently I have to go to the Change order page in manage, and select the add button then get a list of EVERYTHING which I have dredge through to find the items/drawings I want to add.
Would be helpful if the Release item on the manage menu provided an option to ADD TO EXISTING CHANGE ORDER.
Or another approach would be to allow browsing for items/drawings to add using the project/folder hierarchy.
Preferably enabling both approaches would be a great help!!
If this functionality already exists, can you tell me where it is hidden, as I couldn't find it.
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @iain.mcvey, thanks for posting.
I'm not sure if I understood you correctly, but when you are in the Change Order menu and choose the Affected Items tab you can use the drop-down list to choose if you need to add a design or a drawing. There is also a searching tool next to mentioned list. Maybe this will help you to find the desired files faster.
Also, I think your idea makes sense. If I'm not wrong, it's not possible for now. Check the Feedback hub for similar threads or post your suggestion here. Our developers always take all the ideas into consideration.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
