Hi @Ex_Machina_Engineering
This is a known issue and the team is working on it.
You can enable machine configurations manually:
Warning to anyone about to try the following workaround: do not turn on any of the other selections in this dialog. These are under development and are not supported. They are very unreliable and we do not recommend using them.
Open the Feature Flags dialog by opening up your text commands window (File -> View), make sure that the "txt" option is set, and enter "CAM.FeatureFlags". This will bring up a dialog to allow you to manipulate the feature flags directly.
To activate the machine selection, enable the one called "machine-configuration".
Once you do this, it should stay set in later sessions.
Let me know if that answered your question.
