Announcements
Machine Builder not visible, instead the product acts like the machine tool
AubergM
AubergM
I must have done something out of order to get the product to be the machine instead.
Can you help me remove the wrong machine and get the right one in its place?
sutherland-
Hi @AubergM
Do you have a machine selected in your setup?
The problem can be fixed by utilizing a few workflows:
1) Delete/remove the machine from the setup selection.
2) Turn off the Machine Simulation feature flag in your preview features tab.
3) Edit your CPS file and remove CAPABILITY_MACHINE_SIMULATION.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
AubergM
Thank you for the quick reply!
I did delete the machine from the setup tree and lost the tooling paths.
I guess it is best to start over. I will review the help section on adding a machine again.
I don't know what I'm doing to edit the CPS (just discovered what CPS was yesterday).
Thanks again.
