MAC OS Sonoma not displaying materials correctly
camstuff
camstuff
I have just moved to a new Mac Studio running macOS Sonoma 14.2.1 (23C71) and now I am unable to see or preview textured materials and or display proper colours unless RENDERING - Please see screen shots
I have tried multiple materials and it just seems to be getting worse.  This is causing production issues any help would be very welcomed.
Thank you
camstuff
Just in case - the computer is 2023 Mac Studio - Apple M2 Max 32 GB
camstuff
Please see video file attached - it shows what is happening with adding any textures and rendering.
karina.harper
Autodesk Support
Autodesk Support
Hi @camstuff
This sounds like a known issue - FUS-140643 - it should be resolved soon. As a workaround in the meantime, I found that the issue is related to appearances that have a bump map attached. You could turn it off or use a different appearance until this is fixed.
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
camstuff
Thank you very much for the reply.
