Fusion Support
Mac app not loading project contents
8 REPLIES 8
Message 1 of 9
ejdejong1
152 Views, 8 Replies
I have joined a project on the latest version of Fusion on a Mac, and when I click on the project it returns a 'read access denied' call. I've tried reinstalling, rebooting, updating, leaving and rejoining the group, and signing in and out, but none of it works. I can access the files on the iPad app under the same account.
Any tips would be helpful.
8 REPLIES 8
Message 2 of 9
@ejdejong1 If you login to https://login.autodesk360.com/login and go to the same project are you getting a read access error?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 9
I get a “you don’t have the required permissions to perform this operation” when I use that link. I have editor privileges so it shouldn’t be a problem.
Thanks.
ejdejong
Message 4 of 9
@ejdejong1 Can you direct message me your email ID? I can check in the backend if there are any other actions needed.
Autodesk Fusion
Join Fusion Insider
Message 5 of 9
@ejdejong1 Thank you for the email ID. I checked in the back end and it does look good. Can you do the below please:
1. Can you have the other hub owner, remove your access and re-invite again?
2. Can you have them invite my email ID (only temporarily ) with the same privileges as they have given you? my email ID is rajDOTkumarDOTilanchelianATautodeskDOTcom
Autodesk Fusion
Join Fusion Insider
Message 6 of 9
We tried step one but it didn’t work.
You should now have access to the hub with the same position I have.
Thanks.
ejdejong1
Message 7 of 9
@ejdejong1 Apologies for the late reply. I do not have any email with an invite. Can you please let me know what was the hub/project name that you see the invite?
Autodesk Fusion
Join Fusion Insider
Message 8 of 9
It should be “Cal Poly Racing”.
Message 9 of 9
@ejdejong1 @I don’t see any invite email from you. Can you please re invite me to your hub ?
Autodesk Fusion
Join Fusion Insider
