Announcements
Loss of selections - Release: 2.0.12670
jpgX6TC9
jpgX6TC9
Hello
Since upgrading to this version, I lose the ability to select elements (alignment, sketches) and I have to restart Fusion 360.
Release: 2.0.12670
Active plan: Fusion 360, subscription
macOS 11.6 x86_64 (20G165) on MacBookPro14,3
Best regards
Phil.E
It's possible for the selection filter to get stuck on setting for a particular workflow. This is because every time you use a command that has a narrow selection filter, the filter is temporarily reduced.
When this happens, check your selection filter, like this:
If most of the boxes are not ticked, click Select All at the top of the list.
Next, if you can, please help by identifying the workflow you use that removes the selection settings. This is a bug, but I need to reproduce the effect in order to log it.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Phil.E
I think I found a way to reproduce this reliably and have logged a bug. (FUS-102824)
Do you use hotkeys to launch commands? The reason I ask is if a command uses a small set of the overall selection filter, that starting another command quickly (such as with a hotkey) very close to closing the previous command, this can keep only the small set of selections rather than the full list.
In any event, if you notice this, check the selection filter.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
