Fusion 360 2.0.15995 x86_64
It says I'm using Windows Pro 10 22H2 but I'm running Windows 11 Pro.
I have two reoccurring issues since Fusion 360 updated recently.
1) Every time I open Fusion, it tells me my electronic libraries are newer than the most current and asks me to rollback or ignore. I've tried both but I continue to get this.
2) Since last Saturday, I've been working on a project, and I closed Fusion and it said it was saving the project like usual. Sunday I go to open the project and the project folders is there, and there is an icon of my item, but when I try to open it, it tells me there was a problem syncing the project. There wasn't a recovery notification or anything. Thank goodness I found the backup of the project in the user app data fusion folder and opened it, then saved it as a different name. I used that file and I manually saved many times. Later that evening, I open Fusion and try to open that project and the same thing, it says a sync issue and won't open.
I've logged out and logged back in. I'm not sure how to fix this.
I did see another update yesterday, but it's still doing it.
If I click view on the web, I can see both files there and they both show models.
