Looping Login Process
michaelknappca
michaelknappca
Logging in on desktop via windows 10 causes the program to flash an "Unsupported Browsers" page for a fraction of a second and then return me to the login screen.
I have:
-Updated Chrome
-Set a rule allowing fusion 360 trough my fire wall
-Attempted to log in via "https://login.autodesk360.com" on both Google Chrome and Microsoft edge
(Met w/ message "Hub is being configured Please wait...") page refreshes routinely and loads indefinitely
-Reset my password
I can't find a solution on the forum, the help bot, and the phone number.
Any help would be appreciated 🙂
RajkumarIlanchelian
@michaelknappca I am asking out backend team to look at what could be happening with your account. I will update here as soon as I know more.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
RajkumarIlanchelian
@michaelknappca Can you close Fusion 360 and start up again to see if you can login now?
Autodesk Fusion
Join Fusion Insider
michaelknappca
Same issue, I ended the program in task manager and tried to log in but got the same result.  I tried again, then restarted my pc and tried a third time, same result.
RajkumarIlanchelian
@michaelknappca Can you please try logging into https://login.autodesk360.com and see if the hub message goes away? If you are able to login successfully, now can you login to Fusion?
Autodesk Fusion
Join Fusion Insider
tastycandy13
Community Visitor
Community Visitor
I have a same problem in this situation.
Can I get some support?
Please call me and give any help
RajkumarIlanchelian
@tastycandy13 Can you please try logging into https://login.autodesk360.com and tell us what message it gives you? Do you get an email was sent to you message? If so can you check for your email and accept a URL in that email?
If none of the above works, pelase direct message me your email ID.
Autodesk Fusion
Join Fusion Insider
