Logitech Options+ MX Master 3 Button Assignment Fix For Mac
The Problem: Button assignments made within Logi Options+ software did not work when adding Fusion 360 as an individual application.
The Fix:
1. In Logi Options Plus click the + sign in the top right corner to Add Application
2. Instead of clicking AutoDesk Fusion 360, scroll to the bottom of the list and click "Add Other Application"
3. Once the finder box opens, press the COMMAND+SHIFT+ . (period key) simultaneously to show hidden files.
4. Navigate to: HD>Users>(your home folder)>Library>Application Support>Autodesk>webdeploy>production>(folder with numbers and letters)>Autodesk Fusion 360
Notes: (folder with numbers and letters) may be different for you, but it should contain the app you're looking for. I'm using the Non-Commercial version of Fusion 360.
It appears Logi Options+ was trying to use the Launcher app and not Fusion 360 itself.
Running Monterey 12.1
Hope this helps anyone else having the same problem. This helped me assign what was originally the top button "Shift Wheel Mode" to "Advanced Click > Middle Click + Shift" for Orbit.
Replies (16)
corgan.davis
I'm having this exact same issue but on windows...
jeffZVTR3
Observer
Observer
Exactly what I was looking for. Thanks.
jsyshaggy
Community Visitor
Community Visitor
I found the correct path on Windows by following the shortcut so if you open the file location for the shortcut and track it back to it's original path you can then add this into LogiOptions and for me the MX Master 3 now zooms, rotates and orbits without clicking the keyboard
info
Are you also able to elaborate on it for Windows 11 users? I tried jsyshaggy 's option, so I found the folder of the shortcut. But if I go to this folder within Logitech options, it only shows FusionLauncher, not the full app.
Hopefully, there is a fix for this! Cant wait to hear your solutions!
LHeles
is there something new on this topic?
BR,
Lex
maffeo.ezequiel
Same issue here with windows 11 and mx anywhere 2s!!!
kevinbourassa_kb
same problem with my new MX master 3 from Logitech with my new laptop on windows 11.
not able to see fusion 360 on the mx master 3 config app (only fusion luncher which it doesn't work)
need help to config this mouse too 😕
maffeo.ezequiel
kevinbourassa_kb
so did you uninstall the logitech option + then re instal the other app (Logitech option) ?
maffeo.ezequiel
Yes i do.
1. uninstall options +
2. install options.
but u need to use the last version.. its a web versión.
kevinbourassa_kb
well I uninstalled the "option +" app then install the " option " app you gave me
the mouse it self work (with bluetooth) for basic stuff. but the " option app" doesn't detect the mouse so I can't set it up even if my laptop detect it
do i absolutly need to create a Logitech account to use it?
maffeo.ezequiel
I synchronized my Facebook account with logitech..
g.sperlein
Observer
Observer
The Fix works. You saved my live. Thank you so much.
ossemer02
Community Visitor
Community Visitor
I can't find the “webdeploy” folder despite following the step-by-step instructions
vaddirajuabh
Community Visitor
Community Visitor
I found the fusion file at
"/Users/"YOUR USERNAME"/Library/Application Support/Autodesk/webdeploy/production/(random alphanumeric text)/Autodesk Fusion 360.app"
or
Go to your Macintosh HD and do a file search for Fusion 360 / Fusion, you will see multiple fusion 360, click on one and hold the option key to check the path ---> Right click the one with the correct path and "Go to Folder"---> drag and drop that file after you click " Add another application". (JLK, I did download my Fusion from Home Brew )
But only the advanced click(Shift + Middle click) works, and keyboard shortcut doesn't
****I am running MacOS Sequoia 15.0
Hope it helps!!!
etallasAJ46G
Community Visitor
Community Visitor
I just bought a MX Master 3s and it looks like Logitech does not support Fusion 360, and that's their official stance. I got logi Option + to work with Fusion on my Windows 11 machine, but the "Advanced Click" for [Shift + Middle Button] doesn't work with Fusion 360. I'm returning the mouse for something else that will work with 360, because I'm guessing this isn't the only application that I'll have problems with.
