Login error on Big Sur
Ho installato fusion 360 all ultima versione di big 11.1 ; il programma non si apre mi da messaggio errore login. Puoi aiutarmi?
Phil.E
I moved your message because it had nothing to do with the other post. What you are describing is a login problem on Big Sur.
Login can be affected by things like VPN on/off, and if you use more than one Autodesk ID, or if you've changed your email address recently.
Can you please show an image of the error message you are seeing when you fail to login? That's the right place to start with your problem.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
