Announcements
Login after offline
Login after offline
I'm connected to the internet, Fusion works great.
Then I'm not connected to the internet anymore, Fusion still works fine.
Then I close Fusion and reopen it, can't work offline for some reason (is it a limitation of the "free for hobbyists" license?)
Then I go back online.
Then I have to login AGAIN??? Aren't you capable of maintaining access credentials in 2021, like every other program in the world?
Even better issue: since I hate Windows (and Microsoft in general), I use Windows only for Windows-only programs I absolutely need to work with, and dual boot with Linux; tho with stupid Windows being the only "major" OS that still rocks 1980's retrocompatibility, which means localtime and not UTC like everybody else, "time mismatch with the server" causes the user the need to login again, even if he doesn't close the Fusion window, but just adjust the date/time and he clicks "Try again" in the Fusion error popup.
I know I'm a free user and shouldn't "expect" things, but stuff like needing to login every single time the program opens, is an issue even open source (not even "only free") programs should not have, come on...
Anyway, thank you in advance for your help
(meanwhile I finally decided I went through the process of making Windows understand that he's in 2021, it MUST use UTC, so I should not have time mismatch anymore, tho offline+re-login issue still is present of course).
Replies (0)
