Hi everyone, I lofted out this vertical stabilizer, and all looks good except it is deformed in the middle can some tell me how to make it right.
Sorry I sent the wrong file.
1. which loft (name) are you talking about?
2. I recommend that you first edit the numerous errors and warnings.
günther
Loft is finicky,
the large front radius and straight rear rail is over powering.
Better result from 4 half ribs and 2 rails. Second loft or Mirror will get you there.
Might help....
No, I made the loft, by selecting the outside edge of the patches, then front back rails. A one piece Loft, that can either be mirrored as a body, or do the same for this side.
For the Vertical Stab, bottom rib patch - there is a sketch missing as step 2 of the timeline, and the move command is looking for some references that are no longer there. When you see a yellow or red Icon pop up, fix it with Undo.
Might help.
