Announcements
Lofting curves in a weird 3d shape
250871PCH34
Observer
250871PCH34
Observer
Observer
how can create 2mm walls along the entire design where one side of the foil connects to the other side as seen in the photo where I have support beams I just want there to be walls/ ceilings connecting the two sides while keeping everything else empty.
davebYYPCU
You have an airfoil with 3 vertical spars bridging.
Are you keeping those spars or not?  Noy clear.
If not, try to (Surface > Creae >) Thicken the airfoil 2mm.  Might fail because of the trailing edge area.
Might help...
