Fusion Support
Loft to sheet metal and unfolding
8 REPLIES 8
Message 1 of 9
workshopBL96V
190 Views, 8 Replies
Hello
I'm having a little difficulty creating a sheet metal pattern from the attached lofted sketch, ultimately I'd like to have a wrap around template to enable me to hand profile some steel tube.
8 REPLIES 8
Message 2 of 9
@workshopBL96V
Loft is not needed for cylindrical geometry.
Simply Revolve or Extrude surface bodies.
Edit: On closer examination I see these are Cones well not even cones so I guess Loft is required.
Trim.
(and must have rip seams)
Thicken.
Convert to Sheet Metal.
(You will need a tangent planar face.  I would use Autodesk Inventor Professional for this which does not require the planar face.)
Message 3 of 9
Thanks for that, I'll have a look into planar face a little more.
Message 4 of 9
@workshopBL96V
I don't think you will get anywhere with this geometry in Fusion 360.
Edit:  I think you might be able to get it in Fusion 360, but rather than use Loft you will have to use Sweep with Guide...
Message 5 of 9
Have you selected the circles at the top  and bottom of the part? tried to use sweep with both path+guide surcace as well as path+guide rail and get an error warning appear. Doesn't matter if it's in solid or as a surface.
Thanks for the help.
Message 6 of 9
@workshopBL96V
You have to Sweep a line connecting the two circles (not shown in my image) as a Surface body.
Unfortunately I am not at my Fusion machine at the moment.
Message 7 of 9
Hi
So trying it as suggested with a sweep & guides to this point
However I seem to get a line running the length of the part which is what is throwing off the sheet metal function, as you move the mouse across the faces it divides the part along the additional line.
Message 8 of 9
@workshopBL96V
No new file Attached???
In any case - I don't think this is going to work in Fusion 360.
I think you will need a mature design product like Autodesk Inventor Professional.
Message 9 of 9
Fair enough, thanks for trying.
