Fusion Support
loft command
2 REPLIES 2
Artgoodw
98 Views, 2 Replies
loft command
Hi
I have been trying to create this "shampoo bottle" sketch using the spline and loft command following a tutorial.
I have tried numerous times but when I go to select the rails I get the folowing error message (see screen shot) but I should get (according to tut) (see SS2)
Any help would be greatly appreciated.
Art
2 REPLIES 2
jhackney1972
in reply to: Artgoodw
Please attach your model.  It is hard to tell what the issue is from pictures.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
jhackney1972
Please see this Forum post for the solution to this question.
John Hackney
Retired
