Locating a hole on a face in sheet metal
rdosh
Community Visitor
rdosh
Community Visitor
Community Visitor
I created a sketch of a mounting bracket with lightening holes and four screw holes (clearance holes). Each of those holes needs a pair of countersunk rivet holes on either side at a specified distance from the screw hole and oriented parallel to the long sides of the bracket (I'll be adding nut plates to the finished bracket). I created one of those rivet holes (a circle) in the sketch, finished the sketch and then used the flange tool to make it a sheet metal component. First of all, only occasionally does the circle created in the sketch show up as a hole in the component. Secondly, when it does, I can't seem to change it into a countersunk hole with the proper parameters (it's .098" diameter, as specified, but I need a .172" 100º countersink). When I try to use the hole tool in the component, I can't seem to locate it properly. I think that I just don't understand how to use the two location references. I've tried selecting one of the references and clicking a nearby edge to specify the distance but can't get the edge to highlight.
davebYYPCU
Hole Tool works off the sketch plane.
Make the Flange behind the sketch, not in front.
I drew a centre line.  Set mid-point to the big hole, set the length one side to the small hole centre.
Make the Flange.
Use the Hole tool, using the sketch for input.  Select the 2 rivet positions (line end points)
Set dialogue box with correct settings.
Changed the flange centre lines to normal.
When done, mirror the body twice, to save all that sketching.
Might help...
rdosh
Community Visitor
Community Visitor
Thanks! I'm slow but I'm learning! I won't have opportunity to try this out until later today but that looks like what I want.
rdosh
Community Visitor
Community Visitor
Thanks! That worked! It makes sense that I need to have the sketch more "accessible."
davebYYPCU
Not really.  You can do it (flange) your way, and Flip direction in the Hole Tool.
Model would then be upside down, your choice.
Might help….
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
