Loading Texture files from OBJ
I am trying to get a photogrammetry model into inventor. i have created a OBJ using meshroom wich i put into Autodesk Recap for Editing. once it was just the model i wanted i exported it to a new OBJ.
If i load this into Fusion360 the model will load but textureless. Is there a way to load in the textures since they did export along with the model as 3 PNG's.
Screenshots: https://gyazo.com/1d128079923f4a6d32ede4deb1b5a420 & https://gyazo.com/7acaa098be71fdfd62f5f95f28a034b3
Greetings,
Luuk de Wit
Replies (14)
jeff_strater
no, unfortunately, today there is no way to import textures from OBJ files.
Jeff Strater
Engineering Director
So if i understand correctly.
There is no way to get a textured model into Inventor?
jeff_strater
@Anonymous - This is a Fusion 360 forum.  I don't know if Inventor supports OBJ textures.  All I know is that Fusion 360 today does not.  Here is the Inventor forum page: Inventor forum
Jeff Strater
ipendle01
For anyone who still has this question, since 2021 it IS now possible to load .obj files plus their textures and display them in Fusion. If you are not seeing textures displayed, the first 3 things to check are:
1. When you first import the .obj file, it should have a corresponding .mtl and .png/.jpg in the same folder
2. Make sure you turn OFF display face groups
3. Make sure you are NOT displaying triangle edges (they swamp the display, especially with very fine meshes)
mdvorsak9
are you able to render this? I can get the OBJ and textures uploaded but then the render just shows steel.
ipendle01
I dont see any model to try. Did you attach it?
mdvorsak9
Sorry for my lack of info, I was just referencing yours. But here are two images, one with a .OBJ imported with a .mtl/.png and the other is rendered. Basically, the rendering is ignoring the texture and applies the default material (steel). I have tried to unassign the material but it still happens. Maybe this is out of Fusion's scope but I just want the .OBJ mesh to be renderable. Thanks for your help!
ipendle01
ok, yes I am able to get an OBJ with texture to render with the texture.
You need  to make sure you can see the texture in the Design environment first, if you see it there then it should work in Render too (using the settings described in the solution).
I tried assigning an appearance material (stainless steel) but it seems it is ignored when there is a texture.
mdvorsak9
So both of the images that I posted which have textures are in the design and render workspaces. The issue is that when I render it the textures go away and are replaced with steel shown in the rendering gallery (photo 2). So if you render the kangaroo do the textures stay? Thanks again for your help.
ipendle01
Got it. Yes, you are right, when I actually hit "In canvas render" the texture dissappears for me too.
mdvorsak9
Kind of annoying right?! Any idea of how to fix it?
guselfvpa
This way to texture obj seems to now be broken. Is there a new workflow to follow?
Kind regards
Patrik
ReavoEnd
Community Visitor
Community Visitor
Make sure you're using Insert > Insert Mesh, rather than File > Open... -- Insert Mesh loads the texture from .mtl, for me. "Open..." does not.
veikko.vierola
Hey, there is a bug in the Fusion 360 .obj texture handling I presume?
When opening .obj file the .obj file is linked to equally named .mtl file in the same folder. The .mtl file is a text file that includes the information about the  texture .png file that is supposed to be used over the .obj file. The .jpg file is located in the assets folder.
If the obj. jpg file has same name for example color.jpg and then you open new .obj it can happen that Fusion 360 still opens the old texture jpg file over the new object because it has same name.
Workaround: go to .mtl file (open with text editor) it can look something like this:
newmtl Material
map_Kd assets/color.jpg
Pr 1.00
Now change the name of the color.jpg to color2.jpg so that it looks like this:
newmtl Material
map_Kd assets/color2.jpg
Pr 1.0
Now the texture opens normally again.
This is a probably a memory BUG that Fusion 360 has. Autodesk should fix it immediately if this is the case.
