Announcements
Line moves after being drawn
jonhard1298
jonhard1298
Watch the video, can someone explain to me what is happening here? I was able to do the same move on the other side, as you can see in the clip.
https://gfycat.com/healthyclosefrogmouth
sunil.patilQCZZK
Hi @jonhard1298 ,
The file will help us to examine on the issue. How to share a Fusion 360 design
Sunil Patil,
Product support specialist Fusion360,
Autodesk, Inc.
jhackney1972
Just a head up to you, the link you give on how to share a Fusion 360 design, is not a good one to use because if the Forum poster is using a Personal Fusion 350 license, it is not possible for them to do.  It is best use the File, Export, Save, and Attach method, it works for all license types.
John Hackney, Retired
davebYYPCU
Green helper trace is Guide only, will not be sticky.
Turn off the grid.
Make line coincident to the point as next step.
Might help....
