Lathe Machine Configuration
wayhoffmann
wayhoffmann
Lathe Machine Configurations not showing when I select turning, mills do though if I select milling. They were there two weeks ago and working and just disappeared. All I get is "no Data". Not sure how to fix.
WHolzwarth
Same experience here. Any remedy against it?
Walter Holzwarth
wayhoffmann
I found out that if you put your tool processing machine in the post you
don't need to select a machine in the configuration. I am now up and
running!. In the setup folder just don't select a machine.. leave blank,
just be sure your machine is picked int he post processor.
WHolzwarth
Thanks. I'll try it.
Walter Holzwarth
wayhoffmann
Let me know
WHolzwarth
It worked.
I didn't find any machines for Turning in the Machine Library, but in the NC Program menu HAAS Turning /  haas turning was listed as Post.
Well, perhaps an update would make sense.
Walter Holzwarth
