Latest update breaks Fusion
dnrdustin
Observer
dnrdustin
Observer
Observer
The title says it all. I updated, and when trying to launch Fusion I get this.
So I attempt a clean install and get this.
I have attempted reboot, and disabling anti-virus/firewall. I am admin, so I don't understand why permissions would be an issue. Is this some weird lock down because my hobbyist license is a year old? I hope not, I've got lots of stuff I've been working on, all is lost.
Attached is the log file
RajkumarIlanchelian
@dnrdustin Can you please do the below?
1. Close Fusion and make sure the exe is not running in task manager
2. Restart machine
3. Go to add/remove program - Select Autodesk Fusion - Modify/change
This will launch the Fusion service utility
4. Run the repair Fusion
This should hopefully take care of the problem.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
dnrdustin
Observer
Observer
That's actually what I tried before uninstalling and attempting to reinstall. It failed, but I didn't capture the error.
RajkumarIlanchelian
@dnrdustin In your add/remove program, do you have Autodesk Identity manager? If so can you uninstall it and install it again from https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/7zbgTemIhA3ltRs4eACL0g.html
Autodesk Fusion
Join Fusion Insider
dnrdustin
Observer
Observer
I'm unsure what caused the initial issue, but somehow all of my c:\user was hidden and inaccessible. Unhiding allowed install.
