Latest Fusion update can't update derive links.
ekbiker
ekbiker
after updating fusion to the May update, my links can no longer update with the latest.
RajkumarIlanchelian
@ekbiker Can you please confirm which version of Fusion you are on? Are you part of the Insider program?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
ekbiker
Fusion 2.0.18961 arm64 [Native]. I requested to join the Insider Program yesterday, but have not been accepted.
RajkumarIlanchelian
@ekbiker this is the right build you need to be on production.
Can you give some more information on if you see any error when you are trying to get latest?
Autodesk Fusion
Join Fusion Insider
ekbiker
It said to try "Get All Updates" or something similar again. I suspect it was the API call that was failing. It started to work as of this morning.
RajkumarIlanchelian
@ekbiker Good to know it is working.
Autodesk Fusion
Join Fusion Insider
