Fusion Support
Latest Fusion 36 Build 17-04-2023 Not Working
21 REPLIES 21
Message 1 of 22
geoff-hill
633 Views, 21 Replies
Just downloaded update to Fusion 360 now unable to sign back in and get it running
Please get back ASAP
Geoff
21 REPLIES 21
Message 2 of 22
chip.stark
in reply to: geoff-hill
Hi Geoff,
  I'm sorry you are having issues running Fusion 360 after the latest update.  Could you send us the logs for Fusion?  It would help us diagnose what the problem is.
Fusion 360 logs location:
  • Windows:
    • C:\Users\(username)\Appdata\Local\Autodesk\Autodesk Fusion 360\(Alphanumeric Folder)\logs  (Look for all *.log files.)
    • C:\Users\(username)\Appdata\Local\Autodesk\Autodesk Fusion 360\logs  (Look for all *.log files. Logs here when login is unsuccessful.)
  • macOS:
    • Macintosh HD>Users>(username)>Library>Application Support>Autodesk>Autodesk Fusion 360>(Alphanumeric Folder)>logs  (Look for all *.log files)
    • Macintosh HD>Users>(username)>Library>Application Support>Autodesk>Autodesk Fusion 360>logs  (Look for all *.log files. Logs here when login is unsuccessful.)
Id Services Log File location on version 2.0.15775 or newer:
  • Windows OS: %localappdata%\Autodesk\Identity Services\Log\IdServices.log
  • macOS: ~/Library/Application Support/Autodesk/Identity Services/Log/IdServices.log
Thanks.
Chip Stark
Sr. Principal Engineer
Autodesk, Inc.
Message 3 of 22
geoff-hill
in reply to: chip.stark
20210914T150127 I 2440 Version : 2.0.10940
20210914T150127 I 2440 UTC offset : 1
20210914T150127 I 2440 Loading configuration from:C:/Users/User1/AppData/Local/Autodesk/webdeploy/production/13f72ad9475f6108d4ece296925d1894c64ad1cd/Fusion 360.server.config
20210914T150128 I 2440 PROXY: WindowsProxyOptionId set to Automatic
20210914T150128 W 2440 PROXY: failed to query IE proxy configuration - The Proxy Auto-configuration URL was not found.
20210914T150128 I 2440 PROXY: proxy server set to DIRECT
20210914T150129 I 2440 Request(https://ui-dls360.autodesk.com/fusion/version.txt) - workflow: attempt:0 status:200 requestId: UI:1
20210914T150129 I 2440 SLM: device id = f82fe260-2b9c-d25a-60d4-00995a9b92f8
20210914T150129 I 2440 SLM: Initialized
20210914T150129 I 8348 Disk capacity: 857,198MB Disk free: 404,651MB Percentage free: 47 UIThread: no Time: 0.00062s
20210914T150129 I 2440 ADP - 42b07eb4-82b2-448c-8b3a-33e5816cd330
20210914T150129 I 2440 searchAndLoad exec path: C:/Users/User1/AppData/Local/Autodesk/webdeploy/production/13f72ad9475f6108d4ece296925d1894c64ad1cd/Fusion360.exe
20210914T150131 I 2440 SYNHUB: Loading config files in directory C:/Users/User1/AppData/Roaming/Autodesk/Synergy
20210914T150131 I 2440 SYNHUB: Loading config file C:/Users/User1/AppData/Roaming/Autodesk/Synergy/NLauncher.syncfg
20210914T150133 I 11240 LaunchDarkly client initialization process is finished successfully! ThreadID: 11240, Function: Ns::LDCSDKWrapper::initLDCallback, Line: 336
20210914T150133 I 9224 LD CSDK for type Global was initialized with a total time of 0.000002 seconds ThreadID: 9224, Function: Ns::CSDKLDFeatureFlagsManager::getFlagValue, Line: 137
20210914T150133 I 2440 Load Feature Toggle Xml:C:/Users/User1/AppData/Local/Autodesk/webdeploy/production/13f72ad9475f6108d4ece296925d1894c64ad1cd/Fusion/Server/Fusion/Resources/FeatureToggle/FeatureToggle.xml
20210914T150133 I 2440 Live update: disabledUpdateCheck
20210914T150133 I 2440 Live update: FirstTimeHere
20210914T150133 I 2440 Live update: To fire updateNoAction
20210914T150133 I 2440 checkVersion ThreadID: 2440, Function: Nu::WhatsNewBannerCmdDef::updateNoAction, Line: 99
20210914T150133 I 2440 current version: 2.0.10940 ThreadID: 2440, Function: Nu::UIApplication::firstTimeVersionLaunched, Line: 114
20210914T150133 I 2440 last version: ThreadID: 2440, Function: Nu::UIApplication::firstTimeVersionLaunched, Line: 118
20210914T150133 I 2440 display Banner. ThreadID: 2440, Function: Nu::WhatsNewBannerCmdDef::updateNoAction, Line: 102
20210914T150134 I 2440 Load Feature Toggle Xml:C:/Users/User1/AppData/Local/Autodesk/webdeploy/production/13f72ad9475f6108d4ece296925d1894c64ad1cd/FusionDoc/Server/FusionDoc/Resources/FeatureToggle/FeatureToggle.xml
20210914T150134 I 2440 C:\Users\User1\AppData\Local\Autodesk\webdeploy\production\13f72ad9475f6108d4ece296925d1894c64ad1cd\Applications\Simulation\SimCommon10.dll ThreadID: 2440, Function: DllMain, Line: 22
20210914T150134 I 2440 Process attach ThreadID: 2440, Function: DllMain, Line: 23
20210914T150134 I 2440 C:\Users\User1\AppData\Local\Autodesk\webdeploy\production\13f72ad9475f6108d4ece296925d1894c64ad1cd\Applications\CAM360\SimIdealizations10.dll ThreadID: 2440, Function: DllMain, Line: 16
20210914T150134 I 2440 Process attach ThreadID: 2440, Function: DllMain, Line: 17
20210914T150135 I 2440 Libeagle app mode: Hosted ThreadID: 2440, Function: void __cdecl Application::cEagleAppPrivate::Init(void), Line: 236
20210914T150136 D 2440 ADSK Sample Rules read from XML.
20210914T150136 I 2440 Toolbar loader: Stopping...
20210914T150136 I 2440 Toolbar loader: Stopped
20210914T150136 I 2440 ***startSession: BEGIN
20210914T150136 I 2440 getEntitlement
20210914T150136 I 2440 authenticate:begin
20210914T150136 I 2440 login start
20210914T150207 I 2440 ElectronOptionGroup::onReset ThreadID: 2440, Function: NaElectronUI::ElectronOptionGroup::onReset, Line: 181
20210914T150207 I 2440 Going to load toolbar customizations files ThreadID: 2440, Function: Nu::ToolbarManager::loadCustomization, Line: 465
20210914T150207 I 2440 Completed loading toolbar customizations files ThreadID: 2440, Function: Nu::ToolbarManager::loadCustomization, Line: 467
20210914T150207 I 2440 AnalyticItemCounts Terminating with:0 items
20210914T150207 I 2440 WorkflowTrackManager Terminating with:0 items
20210914T150207 I 2440 ADP - optIn: 1 prompted: 1
20210914T150207 I 15860 Workflow start: /v1/licenses 1-6140ab5f-4fc1ae92c17f470c88ee4fbc
20210914T150207 W 2440 Login - Login Dialog Exit
20210914T150207 I 15868 Disk capacity: 857,198MB Disk free: 404,648MB Percentage free: 47 UIThread: no Time: 0.00048s
20210914T150208 I 2440 Going to load toolbar customizations files ThreadID: 2440, Function: Nu::ToolbarManager::loadCustomization, Line: 465
20210914T150208 I 2440 Completed loading toolbar customizations files ThreadID: 2440, Function: Nu::ToolbarManager::loadCustomization, Line: 467
20210914T150208 I 2440 AnalyticItemCounts Terminating with:0 items
20210914T150208 I 9224 Workflow start: GetUserAnaticsId 1-6140ab5f-5e9477f8245f463e9db818bb
20210914T150208 I 2440 AnalyticItemCounts Initialized with:0 items
20210914T150208 I 2440 WorkflowTrackManager Terminating with:0 items
20210914T150208 I 2440 WorkflowTrackManager Initialized with:0 items
20210914T150208 I 2440 ADP - optIn: 1 prompted: 1
20210914T150208 I 2440 login end 0
20210914T150208 I 15892 Autosave background thread started with saveTime: 5
20210914T150208 I 2440 Request(https://js.prd.fusionapi.autodesk.com/fusion360-runtime-config/config.json) - workflow:HTTPClient attempt:0 status:200 requestId:f360_HTTPClient__1-6140ab5f-f7c005308c5a4b268245afc5 UI:1
20210914T150208 I 2440 SLM: Enabled (Production)
20210914T150208 I 2440 SLM: Start session deviceId=f82fe260-2b9c-d25a-60d4-00995a9b92f8 deviceName=DESKTOP-9O4ARRA
20210914T150208 I 2440 Workflow start: SLM_startSession 1-6140ab60-0a72801859054c4492dd5513
20210914T150208 I 9224 Request(https://accounts.autodesk.com/api/security/v1/analytics/user/2TNPJ5T5FC64) - workflow:GetUserAnaticsId attempt:0 status:200 requestId:f360_GetUserAnaticsId__1-6140ab5f-5e9477f8245f463e9db818bb UI:0
20210914T150208 I 9224 LaunchDarkly client initialization process is not finished successfully! ThreadID: 9224, Function: Ns::LDCSDKWrapper::initLDCallback, Line: 340
20210914T150208 I 15860 Request(https://api.v3license.access.clic.autodesk.com/v1/licenses) - workflow:/v1/licenses attempt:0 status:200 requestId:f360_/v1/licenses__1-6140ab5f-4fc1ae92c17f470c88ee4fbc UI:0
20210914T150208 I 15860 Workflow start: /v1/license-check 1-6140ab60-eb9c102ac2544a96b4c9d1d4
20210914T150208 I 11240 LaunchDarkly client initialization process is finished successfully! ThreadID: 11240, Function: Ns::LDCSDKWrapper::initLDCallback, Line: 336
20210914T150208 I 9224 LD CSDK for type Nonhub was initialized with a total time of 0.374319 seconds ThreadID: 9224, Function: Ns::CSDKLDFeatureFlagsManager::getFlagValue, Line: 137
20210914T150208 I 9224 LD CSDK for type Nonhub was initialized with a total time of 0.000003 seconds ThreadID: 9224, Function: Ns::CSDKLDFeatureFlagsManager::getFlagValue, Line: 137
20210914T150208 I 2440 Request(https://f360sc-p-ue1.api.cosv2-p-ue1-dn.autodesk.com/api/v1/sessions) - workflow:SLM_startSession attempt:0 status:200 requestId:f360_SLM_startSession__1-6140ab60-0a72801859054c4492dd5513 UI:1
20210914T150208 I 2440 SLM: session = 36656490
Message 4 of 22
chip.stark
Hi Geoff,
  Thanks for the reply.   If you could drop the Fusion log files, as well as the ID Services log file, in the chat we can look at the files.   The log content you included doesn't show what is causing the problem unfortunately.
  A couple of questions for issues we've seen.  Do you have any other Autodesk products installed on this machine?  What web browser are you using?
Thanks.
Chip Stark
Autodesk, Inc.
Message 5 of 22
@geoff-hill Your version shows as Version : 2.0.10940 which is our update from September 2021. You should be on build 2.0.15995 with the latest.
Can you please confirm if you are on this build by going into Add/remove programs and looking for Autodesk Fusion 360 and its version?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 6 of 22
Hi  I confirm I am on 2.0.15995 installed earlier this morning when all
hell broke loose
Geoff
Message 7 of 22
@geoff-hill Well the log that you attached is in fact from 2021 and hence the version that we see.
Can you gather the other logs that @chip.stark has asked and add it to this thread?
In fact when you launch Fusion 360, if you click on Ctrl+shift, it will launch Fusion service utility. IN there is a gather system info. This will generate a couple of zip files. If you can attach the diagnostic.zip file here that would greatly help.
Autodesk Fusion
Join Fusion Insider
Message 8 of 22
No other Logs present
Diagnostic files attached as requested
Message 9 of 22
@geoff-hill There is no logs attached to the post.
Autodesk Fusion
Join Fusion Insider
Message 10 of 22
Hi
Is there a solution to this problem - I have now been unable to do any
CAD, Modelling or Rendering for over a day now!
Thanks Geoff
Message 11 of 22
chip.stark
Hi Geoff,
  Were you able to generate a diagnostics.zip file with the steps that @RajkumarIlanchelian described?   We aren't able to see any files that you mention that you attached, the diagnostic.zip contains the files with information that will help us see what is causing the problem.
Chip
Chip Stark
Autodesk, Inc.
Message 12 of 22
geoff-hill
Hi Chip,
I replied twice yesterday
See the attached screenshot of my sent file
Have you an e-mail address I can send to directly, as something is going
badly wrong here?
Geoff
Message 13 of 22
chip.stark
I didn't see the screenshot either, something definitely odd going on.  You can send them to me directly at chip.stark@autodesk.com.   I'll get them to the right people if others need to take a look as well.  Thanks.
Chip Stark
Autodesk, Inc.
Message 14 of 22
chip.stark
Hi Geoff,
  I received your email.   We will look through the files and get back to you.
Chip
Chip Stark
Autodesk, Inc.
Message 15 of 22
chip.stark
Hi Geoff,
  The one log file in the diagnostic files indicate it was created by version 2.0.15509, which is the February release.  It is possible the shortcut isn't working as intended.  Can you try running the following?
  1. Delete the short cut
  2. Run Fusion 360 service utility
  3. Run repair
  4. Use the new shortcut created
Thanks.
Chip Stark
Autodesk, Inc.
Message 16 of 22
geoff-hill
Tried to regenerate log on using Fusion 360 service utility Run repair
Firefox refused and gave the following message: _
https://native.auth.autodesk.com/as/authorization.oauth2?aud=https%3A%2F%2Fautodesk.com%2Faud%2Fv2%2...
Unable to communicate securely with peer: requested domain name does not
match the server's certificate.
HTTP Strict Transport Security: false
HTTP Public Key Pinning: false
Certificate chain:
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----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MIIEkjCCA3qgAwIBAgITBn+USionzfP6wq4rAfkI7rnExjANBgkqhkiG9w0BAQsF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MIIEdTCCA12gAwIBAgIJAKcOSkw0grd/MA0GCSqGSIb3DQEBCwUAMGgxCzAJBgNV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Geoff
Message 17 of 22
chip.stark
Hi Geoff,
  I haven't seen that error before.   It could be caused by different things (a proxy server, network security device or DNS problem), I don't have a solution for it.  @RajkumarIlanchelian might have suggestions for this.  I am surprised that you were able to use it yesterday to create the diagnostic.zip file but it is not working today.  I'll check around though to see if there are any ideas on how to get around it.
  In the meantime, you can try to run Fusion360 directly from the installation folder.  It will be found under C:\Users\(username)\Appdata\Local\Autodesk\webdeploy\production.   Find Fusion360.exe and double click it.
Chip
Chip Stark
Autodesk, Inc.
Message 18 of 22
geoff-hill
Hi Chip,
No file named"Fusion360.exe" in fact no exe files just a bunch of  is
present at that location!
Found a version in one of these dated 13/04/2023 so just a few days ago
in a folder
"\AppData\Local\Autodesk\webdeploy\production\22e664d43fce268ac9bf1fa1cda69e4a9585c997"
 but clicking it starts the whole login screen saga which I still
cannot get through!
Geoff
Message 19 of 22
geoff-hill
Okay - Drastic Solution, needed to completely unistall Fusion 360
Reboot twice to clear and log out of Fusion 360
Then re-install from scratch! then and only then was I able to log in using Win 10
now up and running!
Message 20 of 22
chip.stark
Hi Geoff,
  I'm really glad to hear you are up and running now.  Odd that you had to reboot twice but if it worked no arguments.  If you need any further help please let us know.
Best wishes,
Chip
Chip Stark
Autodesk, Inc.
