Announcements
Lagging text edit in Drawing mode
tedbradley314
tedbradley314
I have to restart Fusion 360 2-3 times per day.
When you first start the program, the text edit works great. It's responsive as expected.
As a few hours roll on, it will become very slow and won't update as you type.
Then if you restart the program it goes back to snappy text updating.
See video.
This is not a file based issue. This has been a persistent issue in hundreds of files over the past 3 years.
I'm on a macbook pro monterey v 12.2.1.
The issue is with all text editing in a drawing, not just the title block.
Pramod.kadam
Hi @tedbradley314 ,
Thanks for posting and apologies to know that you are facing an issue.
Since this is happening for all the drawing files, can you share the diagnostics logs to us?
The video is missing in the post, please attach that too.
Also If you remember certain sequence of operations causes this issue, please add that too which will help us to find the root cause of the problem.
Pramod Kadam
Product Owner
Fusion 360 Drawings
