Set keyboard shortcut for Finish Sketch to Ctrl+Space. It doesn't persist between sessions.
Solved by lance.carocci. Go to Solution.
Hi @motorhobo, sorry you're experiencing this. We've confirmed the issue and are investigating.
It appears the issue is with "ctrl+space" rather than Finish Sketch - I can't get it to stick for any other commands, but using a different combo for Finish Sketch seems to persist. I realize this doesn't solve your problem, but hopefully provides a workaround for the moment.
Thanks, Lance. I like Ctrl+Space for this because I use it so much, so I'll just redefine it at every start for now but thanks for confirming.
That's still seems to be a bug, every time I restart fusion 360 shortcut "q" I assigned to "change parameters" just resets, very frustrating.
