Fusion Support
Just a transparent framework is displayed regardless of Material and/or Appearance selections
2 REPLIES 2
tom_marttila
69 Views, 2 Replies
I have the latest version of Fusion 360. When I create a Body in Design, just a totally transparent framework showing the edges appears on the display, and if I select different Materials and/or change the Appearance, these selections are shown in the Properties of the Body, but they do not show up.
2 REPLIES 2
What is your visual style set to?
Mark Hughes
Owner, Hughes Tooling
tom_marttila
in reply to: tom_marttila
Thanks. It was set to Wireframe, and setting it to Shaded with Visible Edges Only + setting Opacity to 100 % cleared the issue completely.
