Joints changing after pressing ok
shaun.bailey791
shaun.bailey791
Hi Guys,
scratching my head on this one.... If I try and add a joint it looks ok while setting the joint but as soon as I click OK it rotates 90°?
wasnt just this part either, even trying to create a joint with one of the side panels back to the origin creates the same effect.
Thanks in advance for your help
Shaun
g-andresen
please show in a screenshot the position you want to achieve
günther
shaun.bailey791
Hi, The first screenshot is the position that I want to achieve
jeff_strater
This is clearly a bug of some kind.  I created bug FUS-101637 to track it.  I was not able to make it do the right thing.  Wondering about it being a sheet metal component, but not sure that is the problem.
Jeff Strater
Engineering Director
shaun.bailey791
where am I able to track it? I put FUS-101637 in the search but has no results
jeff_strater
unfortunately, there is no way for an external customer to track these defects.  When it is fixed, we try to update any forum threads that generated the bug.
Jeff Strater
