Announcements
Joint won't select bottom of a slot
nicolaMQU4L
nicolaMQU4L
I'm trying to Join two parts of a furniture piece. Usually it works but in this case I have no idea why it won't select the center of a face that is part of a slot.
Hope the video will clarify better and thank for your answers
jhackney1972
Please attach your model so the Forum users can troubleshoot your work.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
jhackney1972
I am guessing, without the model, but I suspect the surface, you cannot find the origin on, is joined to the radii on both sides in some fashion.
nicolaMQU4L
Here is the exported file
jhackney1972
I do not see any issue with placing this Joint.  Be sure to turn off any sketches that are on as they may be interfering with your selections.  Model is attached.
nicolaMQU4L
As you said I had to deactivate the sketches. In other models I had the same problem and I thought I was doing something wrong from the start.
Thanks for the prompt answer
