Joint two components between circle surface to box 02 angle taper surface
kanokwan25310104
kanokwan25310104
I would like to do joint of 02 components between circle surface to 02 angle face surface of box, How I can do this?
https://a360.co/3sPwxA0
jhackney1972
This is my solution.  It is not direct but it gets the job done.  By the way, you will be a lot better of with Capture Design History turned on.  Model is attached.
Edit: I attached another model with a simpler method of jointing the components.  Please ask if you need further explanation.  If my answer solves your issue, please select the "Accept Solution" icon on my post to close your post.
John Hackney, Retired
