Announcements
Joint Issue - Between two faces command missing from right click menu
rwetzler
rwetzler
While in the joint command "between two faces missing" is missing from the right click menu. In the included screencast I make three attempts with the right click menu and there is no option for between two faces.
Not sure what I'm doing wrong.
Note: This part can be found in the Basic Training series under 06-Assemblies. I made a copy of the Piston - Inner to test out the between two faces command.
jeff_strater
not missing, just moved.  It is now on the dialog:
Jeff Strater
Engineering Director
rwetzler
I see, I was watching an older screencast demonstrating this.
